New Content not marking folders blue...
MacSavers
Not sure what changed, but sometime around when 4.9 came out, my folders stopped turning blue when I installed new content and then updated Daz by finding the content in known folders. The content items show with the blue border and 'NEW' logo in the lower right, but the folder they are contained in used to be colored blue also. It made it very easy to see where content was loaded.
Anyone know how to get it to behave that way again?
This is not supported in 4.9 - it has been replaced with the grouping feature, though you can use Smart Content's Product tab to see new sets (you can also sort by Install date in Samrt Content, among other sort orders)
Where would I find info on this grouping feature?
Right-click menu on files or products - by default you can Group as None or New, but you can create your own groups too. You can group files and products individually or the contents of products.
You can sort by group IDs (which are just numbers, New is -1). There's a link from the new features page.
-Rob
Hmm... that's dissappointing. I use a lot of non-Daz3D content as well and since it's not in the Smart Content window, I end up using the Content Library pane. Without the blue folders, it makes it much tougher to keep track of.
-Rob
Wow,thanks for the links. There's lots of good info there.
At least you can save your own filters for use in Smart Content.
I just came back to say that I tried creating my own group according to the instructions that Rob linked to. It worked!
