Interesting bug after latest 4.9 update...
PA_ThePhilosopherPA_ThePhilosopher Posts: 1,039
Hey guys,
So I just downloaded the latest update for 4.9 through the DIM, and when I closed and re-opened Daz, the entire UI appears to be missing (see image below). Any ideas what the issue may be?
Thanks,
-TG
Post edited by PA_ThePhilosopher on
  • rbtwhizrbtwhiz Posts: 2,482
    You installed while still having the application open. Close the application before installing.
    -Rob
  • PA_ThePhilosopherPA_ThePhilosopher Posts: 1,039
    edited March 2016
    Thanks Rob, much appreciated. I also noticed that Daz 4.9 no longer appears in the DIM list. Is there perhaps another way to uninstall it? (its' not in the uninstallers folder, or windows programs list either).
  • R25SR25S Posts: 595
    edited March 2016
    via System/Programs/de-install programs or in Windows/Apps/DAZ 3D (right click - un-install)
    Post edited by R25S on
    If you can't get DIM to reinstall it, you will probably have to download the manual installer.  That should fix the missing uninstaller...and if you want DIM to handle the install, you will probably need to remove the manual install then reinstall (for a 3rd time) with DIM (t should be back in the Available list in DIM after uninstaling the manually installed version).
