Daz 4.9 G2F breast size
Hi,
Just upgraded to Daz 4.9, but can't seem to find the "breast size" slider when working with G2F figures. Has it been moved somewhere?
Thanks
Hi,
Thanks
Not sure where it originates (base G2F or an add-on), but ...
Awesome! Thanks Simon, got it now. Shaping, Chest etc. It used to be under the main figure, so I guess they have moved it.
I was panicking a bit. That looks an interesting set of features you have there........................
Now all I need is one for G3................................:-)
An 'easy' way to check is to put 'size' in the Search field as it (unlike the product search ...!!!!) works. And category with a matching item will be 'bold' and you can then drill down to the actual entry, which is what I used to 'zoom in' on the G3F equivalent (again, no clue which product it comes with, base G3F or an add-on):
In answer to your question SimonJM, it's in an addon.
The base figure, g3f, only has movement type morphs on the boobs.
