A way to push/pull clothing in 4.8/9?
in The Commons
Is there any built in way that I can push an area of clothing the character is wearing into a crevice like an armpit or bottom or pull out from the stomach area becasuse it needs a crease or is too close ot the body part?
Thank you
DForm (parametric or weight map depending on detail). Push modifier with a weight map.
Some of the fit control type products might help also.
Some items also have similar morphs under the shaping tab.
Thanks for all the replies. I tried to create and use the deformer and push modifier and these appear to require some guide. Is there some instructions on these please?
Nevermind, I figured it out. thank you!
