mcjSaveAnim: Save material and mcjJet's particle animations as Daz Scripts
mCasualmCasual Posts: 4,607
edited November 2014 in Freebies
mcjAniMatSave is Here !!
https://sites.google.com/site/mcasualsdazscripts4/mcjanimatsave
the manual will be improved monday sept 8
it lets you save material animations created with MatAnim
https://sites.google.com/site/mcasualsdazscripts/matanim
and particle animations created with mcjJet / mcjJet2
https://sites.google.com/site/mcasualsdazscripts4/mcjjet2
Since i learned that DS 4.6 doesn't save the animation data from the material properties
and since matAnim, mcjJet1 and mcjJet2 animate material properties
i wrote ( almost ready ! ) a script that can save the animation data as a sort of material preset file( daz script )
in the case of mcjJet animations, you'll even have the option of saving the particle positions, orientations, sizes plus the material animations
in one script
you could use this to distribute special effects
the end user would simply load the same special figure used by mcjJet, and apply your custom animation script
the scripts will even be DS 1, 2, 3, 4 compatible
note the nyan cat animation was created using MatAnim and Vertical Tiling Offset animation
and the image-strip shown here
Post edited by Cris Palomino on
  • mCasualmCasual Posts: 4,607
    edited September 2014
    making it ds 1,2,3,4 compatible,
    the exporter
    and the importability of the scripts produced
    1920 x 1080 - 546K
    1920 x 1080 - 637K
    Post edited by mCasual on
    ok getting back to this after trying to make high waisted shorts for Aiko3
    i'd say the script will be ready tonight matter of minutes or an hour or 2
    1920 x 1080 - 243K
    1920 x 1080 - 398K
    1920 x 1080 - 269K
    1920 x 1080 - 218K
    1920 x 1080 - 194K
    cool i'm closer than i thought !
    most of the work left is back/forward compatibility coding
    1280 x 720 - 102K
    1920 x 1080 - 202K
    this StarWars-worthy MatAnimation was created in DS 3.1
    exported as a DS1/2 compatible script ( .ds )
    Applied in DS 1.8 and rendered in DS 1.8
    fig 2 MatAnim'ated displacement map in DS1.8
    but the exporter script is unfortunately not yet DS1.8 compatible
    i hope i can make it work tonight !!!
    fig 3 - almost there
    exported as .dsa format
    imported/applied in DS 3.1
    but the image-map didnt follow .... yet
    fig 4 : yay it works !
    the image-map on strength properties was not implemented, it now is , in the DS 1,2 version
    fig 5 almost ready !!
    i didn't re-test DS4.6 though ...
    412 x 355 - 60K
    1920 x 1080 - 395K
    1920 x 1080 - 369K
    320 x 180 - 174K
    320 x 180 - 202K
    Ds4.6 tests ...
    yay, the mcjJet (particle-figures animation ) animations exported from DS 4.6 are compatible with ds 1, 2, 3
    which is not so easy since figures and bones and materials are quite different
    1920 x 901 - 402K
    320 x 320 - 192K
    ( bummer my google-drive gif anims are no longer accessible on my google-sites ....
    i'm really annoyed by Facebook and google's anti-gif ways )
  • juve_satrianijuve_satriani Posts: 138
    Excellent and thanks for your efforts to make DAZ Studio more useful
  • RuphussRuphuss Posts: 2,631
    hey that works
    thank you casual
    REPAIRED !  REPAIRED !  REPAIRED !  REPAIRED !
    Some changes occured in Daz Studio 4.9's script engine ( maybe 4.8? too )
    and they made matAniSave produce unusable material-animation files
    but i repaired it and it seems to work fine now
    the funny thing is, the version of the script for DS1/DS2 was pretty much what i had to do to regain compatibility
    technical detail : in DS3 and DS4, before, you could write file.write( myfunction ); and the source code of myfunction would be written out
    but with DS 4.9 it writes [native code] ... So the new (and very old) versions write line by line the source code of "myfunction"
    another Note  rendering the animation shown here failed with iRay - apparently, Daz Studio doesnt expect UV
    tiling to be animated and doesnt send them to the iRay render engine during render of animations
    BUT a while ago i wrote a script that lets you render a subset of frames, and i think, since this script manages the rendering .... maybe it's a work-around !
    https://sites.google.com/site/mcasualsdazscripts/mcjlistrender-for-ds-1-2-3-4
    if this doesnt work, try texAnim or even voodoodaz ( i mean when you really really want it ! )
