Improve the ambience in your Daz Studio life
mCasualmCasual Posts: 4,607
edited March 2016 in Daz Studio Discussion
imageThat's a Daz Studio preview ( openGL) render, it renders in 1 second
i had the Edit/Preferences/Interface/Per Pixel shader  option ON, because it lets me
see the gold/chrome effects ( the balcony and door ornaments ) in preview mode
there's 2 drawbacks to that mode which i overcame here
1 - the "ambient color" and "ambient strength" settings of the surfaces have no effect
the work around: in the upper-right corner of the Diffuse Strength channel, click on the "Parameter settings" button
turn the limits OFF on that setting
set the Diffuse Strength to 150%
the walls and floors were brightened that way
note that this is not identical to "ambient" it just augments the diffuse brightness
2 - when the "Per Pixel shader"  option is off, if you create a gigantic sphere, and apply an image on its Diffuse Color channel
then set the diffuse strength to 0% and the ambient color to white and the ambient strength to 100
you get a Live !!! ( preview i mean) environment dome/sphere.
but when the "Per Pixel shader"  option is on, we only get a pitch-black sky and the solution in [1] doesnt cut it either
so ...
iRay's environment images are a special type of panoramic images called equirectangular or spherical
for iRay's needs, the HDR image format is preferred, but you can also use jpeg images and it works well
so if you want more interesting backgrounds and lights "from the sky dome" google for words like equirectangular or spherical
one place to get some with permissive licences is the sIBL archive
www.hdrlabs.com/sibl/archive.h…
so lets say you have the Hamarikyu package of images, it contains among other things the Hamarikyu_Bridge_B_preview.jpg image
create a daz primitive sphere ( or get one as a poser prop from my site )
1000 meters diameter
lower that ball by 50000cm
the sphere is now centered at 0 0 0
apply the image to ................... the Reflection Color channel of your gigantic primitive sphere
set the reflection strength to 100%
You got a live sky dome !
but it's upside down, and rotating the sphere wont solve this
open your jpeg image in a paint program
flip it upside down, mirror it left-to-right
save it
so that image applied to a giant mirror ball now looks like a Live SkyDome preview
Post edited by mCasual on
