Daz GUI has broken
Janus3003
I downloaded and installed today's update while I was running Daz earlier. I continued working during the download and install, then saved and quit soon afterward. I don't know if it matters, but I also deleted the Reality engine after I closed Daz.
I opened Daz again, and it looks entirely different. All panels are white, and there are no icons in the top menu. Style and Layout don't have any options for me to pick to put this back the way it was.
Was it the update that broke something? Maybe something I deleted?
Thanks.
Not the update...the installing it while running.
If you used the DIM to do the update, make sure Studio is closed and redo the update.
That fixed it! Thanks. Now I feel kind of silly, but oh, well.
This happened to me too! How do you redo the update?
If you haven set the DIM to delete the downloads after it installs, you can either go to the folder and run it manually (it's fine to install right over top, the installer will remove the old install during the process) or try to have DIM run it again.
If DIM does delete the downloads, then you need to either grab the manual download or remove it in DIM and let DIM redownload and install it.
I think it did get deleted after installing. How do I get the manual download? And thanks for the help btw
Oh wait, I might have found it
Yes, looks like it's fixed. Thanks!
