"220 Emotions for Genesis" not working in daz 4.9
Need help getting the "220 Emotions for Genesis" to work for Daz 4.9. The last time I used it was I believe Daz 4.6. Now it is not showing at all. I had to add the directory it was in and still did not work. Is it because all of the files are dsf or maybe all of the files are installed in the data folder?
Post edited by brianomd on
Morph files should be in the Data folder, in .dsf format, and should not be showing in the content panes within Daz Studio (there may be presets for applying them, however). The morphs will usually load with the figure and be available as sliders in the Paarmeters and (for expressions) Posing panes.
Doublechecked on mine in 4.9, works ok. Posing or parameter pane under pose controls/head/expressions, from there you can expand further to get the categories or just scroll through all the sliders.
Thanks. Daz team helped me out on this one.
You must choose the head and then the 220 expression morphs will show.
