Container View doesn't show up.
This is what is showing on my screen.  As you see, the window>panes>content library is selected.  Is there anyway to reset the preferenced in daz 4.8?  I'm not sure what I did, but I am now unable to see the library [ container view] in the right side of the display. Nothing I have tried will change the screen to display it.  The only way I can find a product is to type in the name un the SEARCH at the top right.
Any help would be appreciated.
JimC
  • Richard HaseltineRichard Haseltine Posts: 108,785
    If you look at the top of the Content Library pane, just above the files list there are two bars with dark areas in the middle - those are collapsed panels, and you click the dark area to open/close them. You have closed the container list - the lower of the two bars - so click again to reopen it.
    669 x 442 - 40K
  • pimanjcpimanjc Posts: 11
    Richard,
    Thank you so much for the help.  I must have clicked on the dark area while trying to move the slider over.
    JimC.
