Im trying :(
Cant seem to get my lighting down like I want
  • RCDescheneRCDeschene Posts: 2,816
    What are you trying to accomplish here, exactly?
  • KhoryKhory Posts: 3,854
    Iray or 3dl?
  • AngelmanAngelman Posts: 42
    I don't know the difference between the two.Lso I'm not sure.
  • BeeMKayBeeMKay Posts: 7,019
    edited March 2016
    If you go to the render tab, then check out the "Render Engine". By default, it should be "Iray"
    I assume that you are rendering with the default setting, so that should be "Iray" and "Dome and Scene".
    Also, you are rendering in a closed room, where the only light seems to be the coming from the side, and from the small glow.
    The scene setup looks good, I like the dynamics in it. smiley
    Can you please also post your scene settings, so that we can see what light sources you are using?
    So, what effect do you want to achieve? Is the image too dark, no light from the right side? Please let us know. If it appears too dark, it could be a simple case of adjusting your tonemapping, or enter more lights into the scene.
    This tutorial offers a good intro into Iray. Some of the lights were named differently when 4.9 came out; basically, you do not have separat lights for Iray and 3DL inside of the default lights that you can insert, but they are combined.
    http://sickleyield.deviantart.com/journal/Tutorial-Getting-Started-With-Iray-519725115
    The second post is a thread which has, in the middle parts, some examples about lights and tonemapping:
    http://www.daz3d.com/forums/discussion/59766/lights-gloss-and-shine-on-skin-iray
    558 x 421 - 35K
    501 x 447 - 46K
    331 x 260 - 16K
    487 x 621 - 49K
    Post edited by BeeMKay on
    Okay I got it..thanks for the help..
    1200 x 970 - 513K
    Trying again
    960 x 776 - 114K
    928 x 750 - 95K
  • frank0314frank0314 Posts: 14,734
    What effects are you trying to accomplish?
  • I can't find the tone mapping option in Daz Studio 4.9 Pro T_T  Just renders presents. Please help!
    500 x 650 - 862K
    1366 x 728 - 222K
  • Richard HaseltineRichard Haseltine Posts: 108,573
    In the Render Settings pane, go to the Editor tab.
  • HavosHavos Posts: 5,600
    edited March 2016
    Looking at the renders you have posted, they look to me that they were done using 3Delight rather than iRay, and 3DL has no tone mapping.
    Edit: I missed you last render, of just the dress in the corridor, that does look like iRay
    Post edited by Havos on
  • I cant find the editor tab. Please :(
    1366 x 728 - 783K
    You are in Parameters...you need to be in Render Settings.  It should be the one below the Cameras...
  • I don't have the render settings tab. I'm doing something wrong?
    1366 x 728 - 787K
    Use the menu, Window->Panes (Tabs)->Render Settings
  • Thanks!!! laugh
