tiny clothes import, normal size genesis model
village_residuumvillage_residuum Posts: 0
You can see in the screen shot that there is an item high lighted between two feet. This item is a jump suit that I want to actually fit onto the model in Daz. Any idea and solutions as to what is going to cause this? and what can i do to fix it?
thank you
  • village_residuumvillage_residuum Posts: 0
    Sorry! Here is the picture
    696 x 570 - 61K
  • JaderailJaderail Posts: 0
    First: If it is not RIGGED to move with the Figure your using, It will just load as a static prop.
    Second: It will need to be Imported at the Default Daz Scale or Poser Scale, depending on the software used to model the item.
    The first one is the part that will make it unusable until you get it converted to Genesis or another figure.
  • PendraiaPendraia Posts: 3,616
    Hi,
    without knowing exactly what you are doing...I'm assuming you are importing the object from a modelling program. If so your import settings look to be for Poser.
    If you tell me what process you are using I could probably help more...
    cheers
    Pen
