BUG REPORT: dzApp->getContentMgr()->findFile() not working
BUG REPORT: dzApp->getContentMgr()->findFile() does not appear to be working correctly in DAZStudio 4.9 (but it is in DAZStudio 4.8). For example, the code below returns "". The walnut.png file is present in C:\Program Files\DAZ 3D\DAZStudio4 Public Build\shaders\iray\resources\walnut.png.
Thanks (I have also reported this in the 4.9 release thread - apologies if this is not approriate).
Paul
Post edited by pkinnane_44e978d933 on
This is not a "bug." The
DzContentMgrclass is described as:The description on
DzContentMgr::findfile()states:As the ./shaders folder is considered to be more "plugin" or "resource" than "content," the
DzContentMgr::findfile()function is not going to find a file that resides within it. Hence the empty string return value.The following will give you the absolute path of the file in your example:
-Rob
Thanks Rob
The doco for DzContentMgr::findBaseDirectory() is....
Given an absolute path, this method traverses the content directories and attempts to find the base (mapped) folder.
If I...
Then folder returns with "C:/Program Files/DAZ 3D/DAZStudio4 Public Build/shaders/iray".
So findBaseDirectory() thinks walnut_spec.png is in a content folder.
So I believe that either findBaseDirectory() is bugged, or findfile() is bugged - take your pick :-)
Paul
@ walnut example.
How exactly are Base directories defined?
@ vase example
compare:
http://www.daz3d.com/forums/discussion/comment/1024672/#Comment_1024672
additional steps performed:
- installed content with the DIM in Studio Pro BETA - version 4.9.1.30
textures for content installed with the DIM were found in OctaneRender for DAZ Studio 3.0.6.13 (64 bit)
textures for content installed with DAZ Connect are NOT found in OctaneRender for DAZ Studio 3.0.6.13 (64 bit)
-> It is not a DAZ Studio 4.9 issue in general but an issue with certain directories like resources or DAZ Connect.
Is it possible that the path indicated in the Content Directory manager under
Content Sets
Content Directories
DAZ Connect Data
is not checked when cylcing trough NativeDirs, PoserDirs, ImportDirs, BuiltInDirs
Its actually a case of being "caught in the middle."
The
DzContentMgrAPI has evolved a bit since the 4.5+ SDK was published (i.e., it has gained support for mapped MDL directories, among other things). Said evolution has not been published as an update to the public SDK in large part due to the fact that issuing an SDK update has a ripple effect on end users that has historically been rather inconvenient for them. We've tried very hard to mitigate that as much as possible this time around. That being said, we do recognize that exciting/new areas of Daz Studio are not accessible to plugin developers (but are, to varying degrees, to script developers) and we have been discussing the best way to address that while maintaining ABI compatibility.The version of
DzContentMgr::findBaseDirectory()that you are using (because it is the only one that existed when the 4.5+ SDK was published) had no concept of what a mapped MDL directory is and so theuseImportFoldersparameter represented whether or not to look in Poser mapped directories and other mapped import directories. As part of this evolution ofDzContentMgr, and being that MDL is not native to Daz Studio, MDL mapped directories have been recently added to the list of directory types considered to be "import folders" for theDzContentMgr::findBaseDirectory()function. The additions to theDzContentMgrAPI include an alternate version ofDzContentMgr::findBaseDirectory()that allows a developer to specify an enumeratedDirectoryTypesvalue, similar to the second argument toDzContentMgr::findFile(). Further, the list of enumeratedDirectoryTypesvalues has grown. One of these new enumerated values isMDLDirs, which represents a value of0x10.One thing you may be able to do (I'm in transit, so I cannot confirm at the moment) is include the
0x10value with the second argument toDzContentMgr::findFile(), so that it behaves in a manner that is more consistent withDzContentMgr::findBaseDirectory():To be exactly consistent with
DzContentMgr::findBaseDirectory(), you would also need to include the newCloudDB(0x20) andCloudDir(0x40) enumeratedDirectoryTypesvalues as well.-Rob
Rob, thank you for taking the time to fully explain what is happening in this situation. Your proposed code to resolve he problem works! Thanks
Paul
