Daz Studio Missing Files
Hi All,
OK, Im sure its something I d'id, but I cant, frankly figure it out. Poser was SO intuitive. I installed everything via Daz Install Manager. I installed 'Studio first to make sure it was in there, then set the rest of my files to install overnight. What I get is this:
ANY help or advice would be most appreciated. I have NEVER been able to get DS studio to work correctly, and I suspect its where the files are, but Im completely lost...
'Arc
Can you post these 2 screenshots:
1) In DS, Edit > Preferences > Content Library > Content Directory Manager, expand the "DAZ Studio Formats" and "Poser Formats"
2) In DIM, on Ready to Install tab check the "Show Details" box in the lower right
Fix'
Thank you for your response. Here are the two screenshots you requested.
`Arc
You need to add the path Daz Install Manager is using ( C:\Users\Public\Documents\My DAZ 3D Library ) to DS under both Daz Studio Formats and Poser Formats.
Fix'
THAT did the trick! Thank you SO much!
Arc~
