Daz Studio Missing Files
Hi All,
OK, Im sure its something I d'id, but I cant, frankly figure it out. Poser was SO intuitive. I installed everything via Daz Install Manager. I installed 'Studio first to make sure it was in there, then set the rest of my files to install overnight. What I get is this:
ANY help or advice would be most appreciated. I have NEVER been able to get DS studio to work correctly, and I suspect its where the files are, but Im completely lost...
'Arc
  • fixmypcmikefixmypcmike Posts: 19,709
    Can you post these 2 screenshots:
    1) In DS, Edit > Preferences > Content Library > Content Directory Manager, expand the "DAZ Studio Formats" and "Poser Formats"
    2) In DIM, on Ready to Install tab check the "Show Details" box in the lower right
  • Fix'
    Thank you for your response. Here are the two screenshots you requested.
    `Arc
    1370 x 767 - 281K
    567 x 532 - 91K
    You need to add the path Daz Install Manager is using ( C:\Users\Public\Documents\My DAZ 3D Library ) to DS under both Daz Studio Formats and Poser Formats.
  • Fix'
    THAT did the trick! Thank you SO much!
    Arc~
