Loading Morphs > Reverse Deformations > Load Pose?
Greetings,
I notice that there is 'Load Pose' option in Morph Loader Pro (see below). Is there a way to pose, correct deformations, then load the pose to extract the individual ERC links?
    The pose option means,, when  you select pose file,
    tthe Figure pose will be.auto applied, untill, morph loader make new moprh as reverse defomation from current Figure shape.
    The Usage is,, I think,, you can import multiple morph obj files,   for each pose  then generate new morphs  at once.
    without it,, you need to manually change Actor pose,,(or apply pose preset ) (pose1) ,
    then  import moprh1,obj, by morph loader, with Reverse defomation..  make morph1.
    change pose2,, improt moprh2.obj ,, with Reverse defomation,, make morph2,
    , chane pose3,, import morph3,,etc.
    The ERC option have meaning only when you overwrite morph (which include ERC)  with new improted obj. I think.
