Is there a way to install multiple products at once inside DAZ Studio
I'm discovering DAZ Studio... It's nice to have access to all products we purchased directly inside DAZ Studio...
But is there a way to install multiple products at once ? Instead of having to double click on each products individually.
Thanks for your help :)
  • rbtwhizrbtwhiz Posts: 2,485
    edited February 2016
    In the Smart Content pane, use extended selection (i.e., combinations of pressing/holding the Ctrl/Cmd and/or Shift keys to multi-select, just like in Windows Explorer or Finder), or marquee selection, and the Context Menu (i.e., right click).
    When the user selects an item in the usual way, the selection is cleared and the new item selected. However, if the user presses the Ctrl key when clicking on an item, the clicked item gets toggled and all other items are left untouched. If the user presses the Shift key while clicking on an item, all items between the current item and the clicked item are selected or unselected, depending on the state of the clicked item. Multiple items can be selected by dragging the mouse over them.
    -Rob
    (edited to clarify... Smart Content pane)
    Post edited by rbtwhiz on
  • Thanks - in fact, I just discovered I should use the 'Smart Content' instead of the 'Content Library'. When you use the 'Content Library', you can choose only one product at a time to install.
    Basil
    Correct. Multiple selection of Products (or any other type of container) in the Content Library pane is not supported.
    -Rob
