Checkering texture in New Colony
Joe Webb
I need some help with this issue but I'm afraid I've figured out the answer.
Please see the image. Notice the checkered textures on the New Colony walls. It comes up in the Iray render, with the iray material applied.
Is this a part of the texture? I opened the textures and don't see this. And the door renders great. And it doesn't render with that pattern in 3Delight, with either the 3D texture or the iRay texture applied.
Is this a function of not having adiquate graphics card? I don't think I've run into this problem before, ususually it just takes a long time to render instead of giving weird texture effects.
Its texture compression, you need to got the render tab and up the minimum values.
*edit* more precisely - Render tab - advanced - texture compression:
Change the values to something like 4096 / 8k.
Well doggone if that wasn't it! Works perfectly now.
Thank you
Welcomes
