Neutral Gray skin colour for Genesis 3
Hi,
The original Genesis figure had a neutral gray material preset.
Genesis 2 and 3 do not have this.
I have applied the neutral gray material to some Genesis 2 figures successfully but not to any Genesis 3 figures.
Is there a simple way to have my Genesis 2 and 3 figures always load with the neutral gray material as the default skin colour?
There are lots of discussions on getting more and more realistic skin colours but I only want the plain gray for everything as I use DAZ for base figure sculpting
in ZBrush and not for rendering at all. I have never needed to know anything about all of the skin shaders as I've never used them. I only want neutral gray.
Thanks for any solutions offered.
John
Select any single surface on gray genesis and then save that as a shader preset. When you save it be sure to uncheck the UV option. Then you can use that preset on any surface including genesis 3 surfaces. Just be sure you have both the object/model selected and the surfaces selected before you apply it.
thre is this one G3F Grey Materials
Thank you both so much for your replies. I have downloaded the gray material from Deviant art and it works a treat. I've also done the surface option and that works a treat too! All in all I feel very fortunate to have two solutions that both work.
Thanks for your help.
John
Glad it got sorted for you John!
Sweet
It wasn't an hour before I read your post I had did a search for that link. So the site was fresh in my History to find again
I needed it again to install on the new machine . . timing
Timing is everything.
And if you would like presets for
Genesis2Female http://www.sharecg.com/v/70543/gallery/21/DAZ-Studio/Genesis-2-Female-Neutral-Grey
Genesis2 http://www.sharecg.com/v/77641/browse/21/DAZ-Studio/Genesis-2-Grey-Material-Presets
V4: http://www.sharecg.com/v/70542/gallery/21/DAZ-Studio/V4-Neutral-Grey
M4: http://www.sharecg.com/v/70544/gallery/21/DAZ-Studio/M4-Neutral-Grey
I thank you, too! Like another poster in the thread said, I like to (sometimes) take models into ZBrush, and a gray material is best. I may also use the DAZ people as models in my comics.
SpyroRue over at Deviantart s still offering for free his "Grey Materials" packs.
for Genesis 2 + G3 and G8 Male and Female.
Very useful for sculpting new faces. - https://spyrorue.deviantart.com/gallery/55077179/Freebies
