Can k4 clothing be made to fit genesis 2 model?
areg5areg5 Posts: 617
I have the add on for fitting V4 clothing to genesis 2. Is there any way to fit K4 clothing to genesis 2?
  • Richard HaseltineRichard Haseltine Posts: 108,591
    Indirectly -you'd have to Autofit to Genesis 1, then save as a figure asset, then Autofit that to Genesis 2.
  • areg5areg5 Posts: 617
    How do I save as a figure asset? I've never done that before.
  • fixmypcmikefixmypcmike Posts: 19,702
    After autofitting to Genesis1, File > Save As > Support Asset > Figure/Prop Asset
    Ok. And to auto fit to genesis, do I create a genesis figure, fit the clothing to it, then delete the figure or is there some other way to do it?
    Load Genesis, fit the clothing, then select the clothing, although I think it prompts you for which item to create the asset from.
    Excellent! That worked really well. Thank you!
    Unfortunately doing a double-fit often causes more problems than it solves. I came up with this problem a while back and made my own K4 autofit clone to remedy the issue. I'm not sure if it's legal to distribute, so I've avoided posting it on my ShareCG account as a result (maybe someone can fill me in on the rules regarding that).
    Anyway, the outfit here was autofit to K4 using the clone I created. As it's a clone figure, it displays K4 in the autofit box as expected and will allow you to fit items in the same way you can with V4 and Genesis items. If it turns out it's possible to distribute the clone, I'll post it on my ShareCG, but I'm erring on the side of caution for now.
    1000 x 1000 - 662K
  • generalxanosgeneralxanos Posts: 14
    If I'm not mistaken, the autofit feature is in Daz studio. Is there any way, or any plans in the future, to allow Poser users to convert K4 clothing to Genesis 2 characters? I've got a lot of stuff I wish I could use with Gen2.
  • AllegraAllegra Posts: 405
    Any news on whether there will be an outfit for K4 to Genesis 2?...love to use some of the clothing on Sklyer and Growing Up characters.
