Hair on G1 Keeps applying unwanted morphs from Genesis' Ears
DrowElfMorwen
So a lotttt of my characters have pointed ears and positioned variously. When a hair is put on Genesis (one made for Genesis) it will fit itself nicely but will also apply the ear morphs, resulting in very messed up looking hair around the ears. I *know* there's a way to tell it not to, but for the life of me I cannot figure it out. I thought I could go under the Parameters for the hair, go to Actor, find the Genesis morph and dial it to zero. But it doesn't seem to be there anymore, and I've tested five different Genesis hairs for this. Can someone plesde help me out? I cannot use any hair I have for my current character :(
Hi, if you can not find auto-followed morph, see "parameter tab option menu", then check on "show hidden properties."
(r-click the tab, it usually show you option menu of the tab, or click small square bar around the pane (top right corner))
auto followed morphs are atuo set as hidden properties. then you need to change option of parameter tab to see them.
after that select hair root, then select "cullently used" (because, if the morphs are not categorized as Actor,, atuo followed morphs are not be shown
as "Actor" cagetories too.) it will show you all morphs currently applied on the hair.
then,, if the Ear shapes are included in one morph,, (eg you have FBMelf morph it can change ear and Fullbody and Face by only one morph,,)
about this case,, unfortunately,, you can not remove only about Ear morphs effect from hair.,, but I think,, you make actor with individual Ear morphs,
then you may easy remove the autofollowed ear morphs without remove Actor Full body morphs I think
if it wrok not well,, please show yourh parameter tab, with "show hidden morphs" option.
And if you feel,, some morphs (eg Elf Ear, Cat Ear etc,,,) of genesis,(or Actor Figure)
need not auto-follow,, you can change setting of each morph (property) by property setting.
click small gear icon of the parameter,, then remove check mark of "auto-follow" , and overwrite the morph (carefully)
after that, all hair not auto follow the morph, when it fit to Actor. (you may need re-load the hair)
OMGOSH I found it THANK YOU!! That stupid hidden properties ALWAYS gets me *derp*
Thank you so mcuh!! That's the part I couldn't remember.
This time I am taking down a note!!
If the ears are their own morph, you can click the gear on the morph for parameters and unclick the autofollow. Not sure about morphs where they are not separate.
Nice, I did not know that either! Thank you :D
