Product disappearing
Cricket
I've been having an issue where random items will disappear from my Smart Content folder; sometimes not even the whole product, but just the textures (or one texture out of five). Is this happening to anyone else?
of course you need select items first, to find material files (I think you do not miss it)
then actually some products in daz shop (not rare) come with wrong meta-data.
they sometimes forget to declare as item, sometime mistake compatibility base, or compatibility with,
sometimes just make products category, but forget to grouping.
though they have meta-data,,
so you need to check the updated topic, then compare your version,
and install the new version again.
but sometimes they version up for other purpose not to remove the meta-data problem.
(and sometimes they do not change version, just correct it, and do not tell officialy
we can check easily)
if the bug report has been send , they will or have corrected it.
so you find it first install new version, then if it will not correct,
I hope you send bug report.
there seems more products which missed meta-data.
Yeah, I did that, but I find items are no longer in my smart content. I just checked, and Jade Assassin uninstalled itself for no reason. I'm constantly having to reinstall items.
