About Daz
bonjour
I have the new version 4,9 installed
I used and prefer to install manually all the products i bought from DAZ in D:\DAZStudio4 64 bits\My Library
But today i just order a new free friday product : canoes ,just availlable in Daz connect oofline
I find instruction for it in FAQ
I have put the .sea and.sep files inside My Daz Connect libray\data\cloud/\install
In the pane option menu for the Smart Content i have click the "Install Offline Products" after loggin
In my content lbrary i have found canoes entry bu no file inside
Can i say that i did not like about this first experience with DAZ Connect ??
Content installed via Connect will not appear under Daz Studio Formats - it will appear in the Products and Categories lists, and in Smart Content. If you want access to the content via Daz Studio Formats find the files in one of the other locations (the products tab of Smart Content is probably the most useful as it shows them organised by type) and make sure you can see the folder under Daz Studio formats (the actual folder name in the list, it doesn't need to be showing its contents) then drag the files onto that folder name to create shortcuts.
Thanks
I finally find it using your suggestions
