Genesis 3 male clone for genesis
Stezza
http://www.daz3d.com/genesis-3-male-clone-for-genesis
Usual question... has anyone tried this product(s) in Carrara and if so does it work?
thanks
No idea but I have the G3M clone for G2 and clothes saved as support asset using it in DS work in Carrara so imagine same thing skipping a generation.
The one I have does not bring up the autofit dialogue in Carrara so needs to be fitted and saved in DAZ studio
I suspect this is the same, as a PA product not an integrated DAZ one
The only G3M outfit I have to test it with is the Basic Wear and it definitely does not work. It doesn't give you the usual auto-fit pop-up to choose the intended figure just like fool says the clone for G2 does(n't). It did give me the "projecting morphs" pop-up but doesn't seem to have actually projected the morphs onto the clothes.
Weirdly though, if I go to fit something for Genesis 2 or M4 or V4, when the pop-up appears V3, Genesis 3 Female and Genesis 3 Male all appear as options! So it recognizes that those clones are there, but won't use them for Genesis 3 clothing for some reason.
I tried with the couple G3F outfits I have and got the same result - it says it is projecting morphs but doesn't actually do anything and does not show me the pop-up to select the original figure. Is there something different about G3 clothing that makes Carrara not recognize it as fittable clothing?
Slightly OT: lately I've been having an issue with both Genesis 1 and Genesis 2 M/F where Carrara loads them to 50% and then just hangs for several minutes. I've never experienced that before and am wondering if some update I unthinkingly downloaded has caused this. Is anyone else experiencing this issue?
thanks for the info
<puts wallet back in pocket>
Have a look at this thread in the commons.
http://www.daz3d.com/forums/discussion/64403/converting-to-g1-g2-g3/p1
