Manga Shader HELP
Cherie_7cc9bd4e
in New Users
I have finally found time to sit down and play with Daz seriously but I need help configuring manga shader that I just got off the store. How do I use the shader?
Thanks in advance
First, it's a 3Delight shader so you need to chnage the render engine setting in the Editor or Advacned tabs of Render Settings to 3Delight.
To apply the shaders you need to select both the object(s) and the surface(s) on the object that you wish to affect - the easiest way to do that is to use the Surface Selection Tool to click on the model (use ctrl(Win)/cmd(Mac) to add or remove items and surfaces) though there are a few cases where that won't work (the eyes on most figures, for example, where there are concentric shells of surfaces and only the outermost will be selected by the tool) - in thsoe cases select the object and then use the list in the Editor tab of the Surfaces pane. Once you have the target surfaces selected just double-click the desired presets to apply them and render.
