Render Stopping Around 30% With No Error
From the Ashes
I am using DAZ 4.9 on a PC. I have 16 GB memory, 4 GB GPU Memory
Recently I have had my render stop at around 30% with no error message given. Any idea what could cause this?
Thanks,
Post edited by From the Ashes on
Time out? Iray is, by default, set to stop after two hours or five thousand iterations regardless of the convergence ( the percentage is how far towards the convergence limit the render has gone)
Thanks Richard, it is indeed stopping after around 2 hours. The image still looks a bit grainy though, could be my lighting...
Yes, if it's only 30% of your target convergence (deault 95%) then it probably will be grainy. Either add more light or increase the time setting in the Progressive group in Render Settings
On it now. Thanks for filling in one of my knowledge gaps.
