extra Genesis icon in smart content after installing 4.5
TSasha Smith
I recently installed 4.5 on to my computer. I am seeing two genesis icons in my people section of smart content. How can I remove the one circled?
Also do I need to uninstall 4 32 bit since I am using 4.5 64 bit now? Are there any benefits to installing the 32 bit version of 4.5? my computer is a 64 bit machine so I rather use 64 bit when possible.
right click on it and select "Removed orphaned file reference".
Could be one is the previous Genesis.dsf file and the other one the new Genesis.duf file. I have them both in my library as well.
I think you may need to uninstall ds 4.0.3 pro 32 bit ver too,
if you use ds 4.5 ver
because "ds 4 .0.3" and "ds 4.5" can not use same one cms (database)
without trouble in one PC HD.
when I tried to install 4.5 64bit RC ver with 4.0.3 32bit,
many same orphaned files turn up ,and each pointer of dsf and duf mixed.
so if I click some file, it could not load correctly.
before I installed both of 32bit and 64bit of ds 4.0.3 and used them together,
since 4.0.3 32 bit ver only have free rip-sync plug in.
but about 4.5, I think 4.5 32bit ver have not free lip sync too,
so if you use 4.5 64bit ver , you need not install 4.5 32bit ver I think.
(but if you keep both , you can test them when met some trouble I feel)
(if there are some better points about 32bit ver, I will install it too,,
