Construction Equipment
tititlemot
Hi all,
I hope I don't post in the wrong forum section. I'm looking for construction equipment such as helmet & vest or harness, does Daz or Poser have them as freebies or even paid?
Thank you very much
Free Helmet in obj format: http://www.sharecg.com/v/43030/related/5/3d-model/hard-hat
Thank you Charlie, but I don't know how to import it to DS & color it. Could you please tell me how? Once again, thank you very much.
Download and unzip the file. Then open DS and under file select import and 0bj for the type. Navigate to the location of your unzipped obj file and open it. Most likely it will already be textured; but if not you can use the surfaces tab in DS, select the surface, and apply a shader.
NOTE: I just tried to download the file to test it for you.and although the description says it includes obj format, .it only has 3D max files These can not be imprted to DS unless you have 3d Max and can open the file in it and then export it as an obj file. Sorry.
There is a free Poser one here: http://www.philc.net/freestuff_archive.htm and it should be useable in DS. Scale about 3/4 of the way down the page and click on the image to download.
There is also a construction hard hat in this set: http://www.daz3d.com/m4-headwear and it is DS ready
