Content Installation
I'm confused...again. 2 questions.
1) whenever I load the Basic Male, Female or Genesis, I get a duplicate files warning. I check the log, note what the dupes are, open my library, browse to that folder, and there are no duplicate files (screen shots attached)
2) Why do I want to install my DPC Content to 'My Library', rather than DAZ3D Library?.When I install V4 Pro through the DIM, it creates Poser Content libraries under My DAZ3D Library. So why can't I put stuff there too?
  • Not duplicate file, duplicate formula. It may arise if you have the same file in two different content directories - My Library and My DAZ 3D Library - or it may happen because you have older versions of the files - though your Victroia 4 shape fiels match mine.
    If you install an item with the .exe installer and then uninstall it there's a chance it may remove files that DIM is also responsible for, possibly leading to missing files. However, with the morph sets for the fourth generation figures you have no choice but to install them to the same content directory (with Genesis+ morphs that isn't true).
