Soft tones Iray Shader?
PhoenixDeFalco
Hey, All! Its your friendly neighborhood supernoob, here with yet another question about Freebies. I'm trying to create a render in DS4.8, with soft, pastel-like tones. I have an Iray toon shader preset, and was wondering if anyone knew of, or was willing to create, a shader preset for DAZ to render an image in Pastel tones, similar to the image linked below. Please note, the image linked to is not my work, and doesn't belong to me, I'm merely using it as an example of what kind of tones I'm looking to reproduce with DAZ Iray. Thanks!
~* Phoenix DeFalco *~
Here's the example image:
http://fav.me/d8hfy8x
Note: I do have permission from the artist to post a link to her pic on this forum.
Post edited by PhoenixDeFalco on
Moved to Daz Studio Discussion as it's a question, not an offer of a freebie. I've also deleted the image - if you want to show anothr's work it's best to link to their site/gallery page.
To do something like that you need even lights - a largely monotone dome image, say - but it's not really the kind of thing Iray is designed for, looking at 3Delight may be better Alternatively you could render out to material IDs - each material gets a random or user specified colour - and then adjust those colours, perhgaps then using a low opacity overlay in luminance mode of a standard render to slightly tone the results.
Is something like this in my gallery close enough to the look you're after? No outline obviously, but pretty pastel.
The main thing is to go into render settings>editor>>tonemapping and setting burn highlights and crush backs to 0, you can also up the saturation and gamma a hair.
If this looks good to you I can whip up a quick preset.
Here are the settings (its an old image so I recreated it a bit) The Zip Contains 3 presets, the main one is the tone mapping settings, the other to combine (environment and a spotlight) to make the lighting setup in the render below
If you already have the lighting set up how you like, just use the render settings.
Also If the settings are making everything too bright go into the render settings and turn down the exposure a hair.
Thanks a lot too
I loved to use iray to make surrealist/toony pictures. That pastel setting is inspiring.
