Rendering one frame with motion blur, could someone remind me?
SnowSultan
in The Commons
I can't seem to remember how to render one frame with the motion blur calculated from animation on the timeline. Can someone remind me how this is done, and if it still can be done using Iray? Thanks in advance.
I don't know if it works in Iray, but here are my notes from 3DL:
Motion blur: In the Render Settings pane's Advanced tab, check the "Motion Blur" checkbox. In the Timeline pane, click or drag the slider to the 2nd notch to create a second frame. Move whatever you want blurred. (Note that instances don't motion blur as expected.) Click on the key icon with the '+' in it. Move the slider back to frame 1, then render. If it is too grainy, in the Render Settings pane > Editor tab > All, set TODO VERIFY "Pixel Samples (X)" and "Pixel Samples (Y)" to higher values (like 16).
Thank you very much. I did happen to come across a tutorial where someone did use motion blur, but I still can't find out if it can be done in Iray. Doesn't appear to look like it, but I'll keep checking.
nope Motion Blur hasn't been added in DS/Iray yet...Iray is capable doing motion blur though, just not for us DS users yet as mentioned here http://www.daz3d.com/forums/discussion/70262/motion-blur-for-iray
Thanks for confirming.
