Good Olive Skin for V7?
in The Commons
I have a good oriental skin, good middle eastern skin, good black skin, a myriad of good caucasian skins - but I can't find a really decent mediterainian olive skin with red under tones (Southern Italian, Greek, or the like). FWSA Adelaine is pretty close, but just isn't quite what I'm looking for.
Any suggestions?
See if this one works for you: http://www.daz3d.com/vincenzina-for-genesis-3-female
I've never tried this in DAZ Studio. I would hope that you could use Shader/Editor. I use Carrara and can adjust the skin color/tone in it's shader editor for any figure earlier than G3 which Carrara doesn't have support yet. On the other hand http://www.daz3d.com/vincenzina-for-genesis-3-female does look nice, it's in my wishlist, and would be a lot quicker.
You can adjust skin tone for Iray skin shaders are well. Biggest problem is figuring out which of the several tones/layers is the one you want.
Which is the good oriental skin? I have a bunch of caucasian and a olive skin but no oriental.
What Generation/Genesis model M/F? I have for G3 "Chiyo For V7" character, http://www.daz3d.com/chiyo-for-victoria-7 , and have have good luck with that... however I didn't try out the skin material which looks like it should be quite good, IRAY or 3Delight, instead I used it for the shaping presets and applied an appropriate skin material from a different character.
I looked at Asian Skin Merchant Resource Texture Kit for Genesis 2 Female(s) , http://www.daz3d.com/asian-skin-merchant-resource-texture-kit-for-genesis-2-female-s , but do not have so can't attest to how "good" it actually it is.
You can find either one of these and more by searching for Asian. But of course you've already done that.
