Copied Library: Can DIM Recognise it?
marble
I've installed DIM on a second PC and copied my content from my Mac to the PC. Then I installed DIM and tried to configure it so that it uses that library as the install target but it complains that the content was not installed by DIM.
Any way around this?
OK - solved. I needed to select the Folder Tree where all the DIM content had been installed. I had other folders above that with Poser style runtimes which were not installed by DIM. Of course, it didn't recognise them.
the use is,
RE IMPORT METADATA
all library contain :runtime/Support/xxx.DSA files
those DSA files are used to re import metadata in 'smart content'
