You've been heard. Response re: 4.9 and Encryption
Adding to Cart…
© 2025 Daz Productions Inc. All Rights Reserved.You currently have no notifications.
There are.
...@ linvanchene
...that's nice and all however there are some really great products at other stores that will be missed. One actually offers "real world" vehicles and aircraft for Poser and Daz which you cannot get here. When I do city scenes I like to use cars, trucks and buses that one can actually recognise and fit with the setting. Same goes for scenes involving aircraft. I also have a fairly large collection of freebies most of which are just as high in quality as commercial content.
As I also only use the Content Pane (Smart Content takes up too much display real estate for my taste and the CMS has failed enough times for me not to trust it), I only have one location to deal with for what I need and have it categorised in a way that is most efficient for my workflow. Were I to allow 4.9 and Smart Content to attempt "reorganising" my library/runtime. it would be a mess.
...for me the opposite was true with the Monthly Freebie as I don't do fantasy work. Maybe that was the one they should have used for the "experiment".
They are not showing up for me
Can you post a screenshot of the page from your Product Library?
It's not the best I can't zoom out fully on my iPhone
Well I have files now for that part of the bundle quickly after posting the screenshot...so if that was you, thanks :)
I will guess that encryption is...very low on your customers want list
In general, the .duf files that look encrypted when you open them are, in fact, merely compressed. Add .zip to the end of the file name, unzip it, and you have a perfectly normal human-readable file.
(.daz files are another matter entirely. Those are neither encrypted nor human-readable.)
Yes. I understand. Please... please understand that I do not in any way hold a vendor responsible for anything that Daz as the company decides to do. I don't.
I also totally, totally support protecting the hard work that PA's/vendors do.
My issues are that with encrypted Connect content, I do not have access to my installer zip files, and that with the way the current Connect system is set up, I also have no control over how I want to organize that content within my copy of Daz Studio. Making "shortcuts" to get clickable icons of my content where I want it placed does not count for having control over my own personal organization of my libraries and where content gets installed. It is not the same thing by any means.
I do not blame the PA's for that which is outside of their control. If Connect is adjusted to address my two main issues, then I will be perfectly fine with using it. At present, though, it is not acceptable for my own workflow, so items that lack a Manual Install, will definitely not get purchased by me.
I'm okay with the notion of encryption as a method to protect the PA's and vendors' hard work. But it has to be done in such a way as to not be punishing to the honest user.
A question...
Is it possible to do an offline install in the latest beta version of 4.9? Even though my main render system is an offline system, I did, very reluctantly, let it connect to the DAZ server to get that one time connection needed to be able to do OFFline installs later on. Even installed that Content Mangler System (as it is possible to shut it down....). But sofar no luck in installing the offline files. They were placed in the designated directory according to the instructiuons DAZ gave, but when I choose offline install, a popup window opens for a split-second, and then nothing........
(I'm still checking 4.9 beta for compatability with my previous saved scenes/character set-ups, and although the results are promising, I'm not yet ready to replace 4.8 with 4.9)
As to encrypted items, not my 1st choice as it limits my possibilities to use with Poser and Vue (For me, DSON was and is a very useful poser plugin to importt genenis and genesis 2 content functionally into Poser....., not possible with encrypted content AFAIK....)
nope, I don't use DIM to download/install content, and the item is encrypted, not been installed before... as said, the offline install window will not even stay open..... just opens for a split second.....,
Can you double-check that the beta is version 4.9.0.63?
checked and double checked , yes it is beta 4.9.0.63
The one time my render system was connected, it also dl'd alot of meta-data (which has no use to me)
I did an online test install for one (different) encrypted item, that worked.
For the offline try I put the .sea and .sep files in the ....\data\cloud\install folder
The online installed item is in the ....\data\cloud\1_##### folder so as far as I can tell, the offline files are in the right place....
Thanks for making Toll booth non-DRM. I really appreciate it.
As I am reading, I'm feeling much the same way here. I want to test so that I can figure out if this might work for me, but I don't want my testing to skew the results and possibly contribute to the condemnation of myself and my fellow PC+ members and DAZ users to a potential eternal purgatory of DRM.
So now I am stuck. And still on page 25...
I'm already running into items that simply do not work properly when installed through Connect. So far items that call on models and textures from other products and any that use a .daz scene file to load content.
The group policy editor allows power users such as yourself to override the factory policy and update on your own terms. I use this on my Windows 10 laptop. This also prevents auto reboots from happening at the worst of times. One caveat, however: You must have Windows 10 higher than "home" version. But as you say, you're a power user so I would surmise that you probably would.
That is why I also will not use connect. And I will not buy anything at the store that is encrypted daz connect only, these products DAZ can keep no matter how good they are.
...it would also make the Daz application leaner for those who don't want to use it. I already don't bother installing plugins and bridges I never would use to minimise bloat.
The last thing I need while working or rendering is being connected to the Net which just takes more CPU and memory resoruces away..
You don't need to be connected to the net while working or rendering.
...actually not as I have 7 Home, but do as much as I can with it In the XP days was a huge power user (which is why I still love that OS). If I updated now, I'd get 10 Home which like you mention gives me no controil over auto updating (or have to pay for the "upgrade" to Pro and then I might as well just purchase an OEM of 7 Pro).
As I understand from the tech sites I frequent, the workgroup option only allows for rejecting "optional", not security updates and it's the latter I am concerned about as there have been bugs in them which caused instabilities on people's systems. I am also the only one on my system as I live alone so it really doesn't make sense to set up a "workgroup" as there are no other users.
The only edition of 10 that allows the same update setting flexibility of 7 and 8.1 is Enterprise, however, I do not own a company, have a server, or employees to justify the high cost.
You don't need Enterprise. I am using 10 Pro and have enough flexibility to download and reboot on my terms.
..we should move this discussion to the Win 10 Auto Upgrade thread.so as not to further derail it.
I see the new freebie is Daz Connect-only again, only this time I think it is a genuine tester product: http://www.daz3d.com/make-a-wish-props
Not interested personally.
It is a pity,
because it is pretty ...
very much so.
*rubs the lamp*
I am wishing for a non encrypted freebie!
Does it work???
Is it non encrypted now???
Do you give it back (without "buying" it before) if it does not work???
LOL
OK I asked this once before and it was ignored, so I will ask it again. Why didn't daz consider different and less invasive and possibly more passive methods of going after pirates? Instead of DRM why didn't they consider adding an encoded serial number to the file itself when it was downloaded? It could have been done without telling anyome and would have given daz the ability to track the unique serial number back to the purchaser once the file was found to be on ware sites? Instead they went with something that they knew would cause their customers to jump up and down. Why?
Welllllll, if somebody gets his/her computer hacked and the files are showing up at warez sites ... who is the culprit?
Really? If someone hacks your computer you really think that they are going to be more interested in posting your studio download files on ware sites over getting your credit card and other more lucrative information? And jsut how many people KEEP their downloaded zip files on their main computer?
