Can somebody please point me to a proper skin for this char
Upirium
in The Commons
Since I frequently recreate celebrities for fun I am working on this lady. The problem is I can't seem to find a good skin for her. So I would like another perspective.
I am using Genesis 2 Female, and Poser, so it'd have to work with both of those things.
She wears a varying degree of different makeup almost every episode so it's kind of hard to find one specific kind of makeup but I would do with something similar. I will add a variety of pics so it will be easier.
Have you tried increasing the bump map values or even making contrast adjusted copies of the bump maps?
I haven't. The only skin I've used with her is weirdly tan even after I've made it lighter.
I've tried using other skins but it makes her face look the wrong shape
Im already having trouble with her fce shape but most skins just make it worse
Textures that appear to alter the shape of the figure is usually the result of having 'burnt-in' highlights and shadows, not much you can do about that. If you are using a skin shader that does SSS (Sub-Surface Shading) that can blow out the tone of the texture if it is to high or has overly saturated color and/or SSS color maps.
That's why I'm looking for other skins that will look better on her.
