Iray documentation?
Whichway Janus
I can't find anything about Iray on the Wiki. Are there documents or threads that would help get me started understanding it? Thanks.
Whichway Janus
I found this here: http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/interface/panes/surfaces/shaders/iray_uber_shader/shader_general_concepts/start#refraction_weight
What I would really like to see though is a guide on using metallicity, it says turning it on overrides most other settings - WHICH ONES? It would be nice if the ones that got overrridden get greyed out. With some other settings not applicable parameters get hidden.
OK, after more experimenting I've found it helpful to look at the links for each shader type. Also, if it doesn't say you can plug in an image map, I think it means that if you do, it is ignored.
Links are on that main page linked.
http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/interface/panes/surfaces/shaders/iray_uber_shader/pbr_metallicity_roughness/start
http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/interface/panes/surfaces/shaders/iray_uber_shader/pbr_specular_glossiness/start
