Carrara Vs connect best practices
I so far have only experimented with connect using Genesis 3 content so no conflicts.
but in future should I use it on otherwise Carrara compatible items I need to know some facts.
First nothing connect will work in Carrara, have already confirmed this with the Medieval Storage
if there is also a DIM option can retrospectively downloading that solve the issue?
(I realize none for that product but say others accidently downloaded through connect)
Does using DS4.9 place my Carrara compatibility at risk? Will it load stuff as connect wiping out existing duf files or just add a connect version too?
can connect products be saved in a Carrara compatible format and what is the best option for this? Scene subset does not work already confirmed that with the Medieval storage but maybe support asset prop figure, will test still, or does it need an obj export reimport or maybe pp2 converter again will look into this as time permits and post findings here.
Am starting this thread as a reference for all Carrara users to post their findings.
«1
  • fixmypcmikefixmypcmike Posts: 19,707
    Yes. DS will use the Connect version unless you uninstall it, but Carrara will continue to use the DS4.8 tables which aren't affected by Connect and are by DIM.  However, while the content data for 4.8 & 4.9 is kept separate, the list of categories is common to both, so if you delete a category in DS4.9 it will be deleted in 4.8/Carrara as well.
    No, it adds a Connect version but doesn't remove any DIM or manually-installed version.  I believe they're adding an option to do so, but it will be an option.
    I think saving as support asset will work; I know .fbx or .obj will work.
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,400
    OK tested the medieval storage room only as support asset prop
    it works but the UV mapping is stuffed
    obj may be the better option
    pp2 exporter created a right mess of obj files and something huge I could not view in Carrara
    edited January 2016
    likewise the UV mapping was broken on the Dragonqueen armour so that does bode well for those buying the Troubadour outfit unless they fix the UV mapping exporting an obj of the original as a new UV maybe
    update it loads OK in studio
    1928 x 1048 - 267K
  • RoygeeRoygee Posts: 2,247
    Does this mean that one would have to keep 4.8 forever to be able to send Daz content to Blender, for instance?
    No, export works the same way, and any product which is available in DIM or manual download is unencrypted in Connect.  That statement was only about the CMS database, not the actual content files.
    edited January 2016
    export works fine on the Dragonqueen armour too as FBX to iClone 3Dxchange, never imported into Carrara not mashed so nothing new there
    an FBX export in iClone 5
    carrara FBX import would make a right mess of that though from DAZ
    but the iClone import would work as prob a Blender reimport so you need to go to a third party app first that Carrara imports FBX from
    This is the Troubador as an obj. UVs are fine. Haven't tried saving it as a support asset yet.
    1045 x 841 - 281K
  • LinkRSLinkRS Posts: 168
    Howdy,  would you mind elaboratign a little on what you did?  I don't have or use iClone, but based on what you wrote, did you export the DragonQueen Armour to iClone via FBX or some sort of "bridge," and the posted render is iClone and not Carrara?  Thanks!
    Rich S.
    that is an iClone render
    it was in reply to the export to Blender comment, I do not use Blender so showed an iClone example
    I could re-export that to Carrara though have quite often to use Octane render and it would have all the animation shown
    my point is going directly from DAZ studio I have had no success with FBX it mangles it but to third party programs like iClone I have better luck
  • its the FBX Import I believe, I have been having issues with some other FBX files, that run fine into Blender, DS and autodesk viewer/converter but blow up on Carrara.
  • HeadwaxHeadwax Posts: 10,451
    that's digusting Wendy, I won't be able to sleep tonight ;)
    the carrara import my daynamic hair decided to error out after the sim so I only could see the guides
    which I then enabled for octane with a freaky result
    often when such errors have occured I lose everything so at least I got this
    tentacoos hair yesheart
  • StezzaStezza Posts: 8,853
    One of this months PC freebies is connect only.... no good for Carrara.... so I cancelled my PC
    again!
  • Yes, I am also seriouslty considering cancelling my PC membership once I've finished stocking up on V4 and Genesis 2 items
    Not even bothering with Genesis 3 as it won't work in Carrara - DAZ Connect just compounds the problem.
    Renderosity may get my membeship for content if DAZ continues to isolate Carrara users.
    Yep, I've already spent more at Rendo and Hivewire than here at Daz this year... Gees may even buy more stuff from CP.. yes
    Seems only to be the toll booth (which I removed from my shopping cart - thanks for the HU), which is a Daz Original, but not PC+
  • I did grab it as free but mostly so I can see what hoops I have to jump through to get it into Carrara
    FBX most likely but may try a few other options and post the result
    that was the purpose of this thread after all, if DAZ deals us lemons, we use the free juicer provided called DAZ studio and make lemonade cheeky
  • mind you DAZ could just release a .car file for us    ...... and Bryce format too, that would be the decent thing to do.
    OBJ,    that's what we need. (with mtl of course)
    The barriers are facing the wrong way anyhow! wink
    You get your passenger to pay.   laugh
  • OK fbx is missing the boom gates in Carrara
    they appear in iClone 3DX5 so not an FBX issue
    1928 x 1048 - 313K
    1928 x 1048 - 340K
    edited February 2016
    loading the cr2 worked
    it's not encrypted!!!!!
    connect only but Poser files as well as duf
    1928 x 1048 - 280K
  • ok they are making this one DIM and manual too apparently .............  ok  ..............next product.........................if free or utterly awesome I have to put misgivings aside and buy
  • Um why do I get ghost notifications from killed posts?
    do I need to conduct a  seance to  reach the dead spirits on the otherside?
    we're not dead, we are just lying down with our eyes closed
    Do you need mouth to mouth?
    ha ha, I thought that read 'moth to moth' . I think it is illegal here in Australia since the chance of spreading dazworm has increased twofold.
    I need to send you something on FB when I get a chance .
    Post edited by Headwax on
    I got lemon juice in me eye!... ouch crying
