MDD Importer for DAZ Studio 4.6
AmariJunAmariJun Posts: 22
edited December 1969 in Freebies
import MDD(Motion designer) file to DAZ Studio scene, but very slow.
Description and download :
http://amarijun.wordpress.com/2014/08/23/mdd-importer-for-daz-studio-4-6/
  • AmariJunAmariJun Posts: 22
    updated:
    version 0.9.0 (8/23)
    add Mdd2text utility, converting MDD format to text file.
    It might improve import performance.
    version 0.9.1 (9/17)
    add "Source Application" buttons, which set sample import settings for Default and MD4.
    Update:
    version 0.9.2 (9/20)
     Improved MDD format check on mdd2text utility.
    Uploaded sample
    DAZ Studio + MarverousDesigner4 garment animation sample
  • KeryaKerya Posts: 10,943
    Thank you very, very much!
  • BlackFeather1973BlackFeather1973 Posts: 739
    A very useful addition to Daz Studio, thank you for sharing. :)
  • LiPengLiPeng Posts: 5
    Master, what can you do a daz import fluid animation obj sequence script,We know that the fluid animation generated sequence of obj grid surface and structure change constantly, DAZ Studio can not import this kind of obj sequence,Thank you!
    zhuxian :
    MDD import script does not handle sequential OBJ, this script would not stand in your work.
    ( Morph loader pro is your convinient rather than MDD importer. )
    And if you’re handling with a sequencial obj with constant number of vertices, how about Mr.vintorix’s “animMorph” script at sharecg.com ?
    thanks.
    (In fact, Fluid is the difficult category representation in the MDD.
    MDD ( in other word, “morph based animation”) since vertex cache after all, it does not have to assume that the number of vertices varies in the sequence.
    I know that the fluid animation has been generated based on the particle in some integrated 3D software.
    For example, this is a way after the collision simulation of the particle, and generate the shape of the fluid in each frame by complementing particle as metaball.
    In this case, the number of vertices of fluid will change from frame to frame, it does not fit in morph based animation. )
  • marcuswilmmarcuswilm Posts: 23
    edited October 2014
    Hi nmizu :-)
    Congratulations and thank you for this useful script.
    Post edited by marcuswilm on
  • MythmakerMythmaker Posts: 606
    edited December 2014
    Just found this and OMG it works the first try thanks to your very detailed instruction and thoughtful example files! I got an animating kimono sleeves dress hahahaha! Thank you arigato.
    EDIT: oh and it's not as slow as you describe. My i7 equivalent didn't even spike much and 1 or 2 minutes it's done!
    Post edited by Mythmaker on
  • larsmidnattlarsmidnatt Posts: 4,511
    edited March 2015
    Late to the party but thanks for sharing.
    Edit: I just wanted to confirm I was able to get this to work just fine. Thanks again.
    Post edited by larsmidnatt on
  • Does anyone know where this script can be found? The site hosting the file has been deleted.
  • will2power
    In some days, I'll upload a program for Windows that convert MDD files to PZ2.
    Add Empty Channel for Characters and props.
  • Thank you for this great script. However, the link is broken for me as well. Can we get a new download link to this script?
    Thank you!
    -P
  • I find the MDD importer  only work in DAZ 4.6 instead of 4.12.
    so how can I import a mdd file  to DAZ4.12?
     AnimMorph can work in DAZ4.12 neither.
    pleae help
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,267
    will this work for any obj series?
    I would use it for Blender animated obj exports and any FBX that can be exported that way
    I guess I can find out
  • Eustace ScrubbEustace Scrubb Posts: 2,730
    I'm not sure the plugin works in current versions either.
  • WizzardWizzard Posts: 36
    amarijun.wordpress.com is no longer available.
    The authors have deleted this site.
