Breast Control Genesis 3 (Commercial)
12346
  • tl155180tl155180 Posts: 994
    edited January 2016
    Zev0 said:
    The previous version had such a morph, but this version will have a better one. Also I aim to have it automatically apply when the figure is in bend positions if the master pelvis bend controller is active.
    You're a star Zev0! Thanks. Really looking forward to it - it'll be one of the few items I pick up straight away upon release.
    To show my faith I've gone and bought Breast Control 3 and Shape Shift 3 today and they are excellent! laugh
    Post edited by tl155180 on
    You know... I've discovered that the Glute Inner Close morph in your Shape Shift 3 product can also be used to achieve the effect I'm after to a certain degree if you take off the limits and give it a negative value.
    Great stuff!
  • Zev0Zev0 Posts: 7,123
    Lol thanks man..No need to show faith. It is a certainty:) After the skin MR I am finishing those will be next.
    Great stuff!
    Ah yes you can use that morph for that as well if limits are off, but I will be creating a dedicated one specifically for that function that is more refined.
  • takezo_3001takezo_3001 Posts: 2,034
    Zev0 said:
    Great stuff!
    Thanks man, thanks a lot! I can't imagine sustaning your dedication as I burn out quite easily...But then again, I'm severly ADHD...wink
    Ha, you have no idea how many times I burn out lol.....the hard part is working through those moments......
  • barbultbarbult Posts: 26,456
    The adoration of your fans should keep you going!
    It does lol..You guys support me, and that carries me through the rough patches. And for that, I am always grateful:)
  • cosmo71cosmo71 Posts: 3,609
    nicstt said:
    Could Normal maps be part of the problem? I've had to edit a couple.
    Normal maps can make your character looking horrible. I for my character AVA has limited the normal map to 25% and have edited also the normal maps itself so I have better looking (my opinion) underbreast area and hipbone are for exmaple (smoother). Second thing is, I have changed the SubD Algo from catmark to catmull legacy and soft corner soft edges.
    edited January 2016
    A normal map is the way of the vendors and character creators to let a low poly figure (like G3F) look like a high poly figure.(like V4)
    Keeping Up Appearances
    Post edited by cosmo71 on
    Actually, it's been mostly used to give additional detail to low poly models used in gaming, since those, especially in older games that ran on the PC, had to accommodate a vast array of different video cards. This was done so that rendering of the moving character model didn't bog down the gameplay side of the game engine. Yes, it can also be used as a sort of "poor man's HD", but to say that V4 is higher poly than G3F is hard to believe without actually showing us the proof.
    At base res, V4 is higher poly than G3F, but G3F with Sub-D level above 1 or with HD morphs is way higher than V4.
    edited January 2016
    I have a V4 as SubD Version and catmull clark legacy SubD Algo, this is a truely stunning version of a 3D Model, you can see her in my gallery, her name is DIXIE
    But another thing on shape shift for G3F. Nice to have waist shape morphs 1-2 and hip shape morphs 1-4 but I miss also fitting glute shape morphs for the hip shape morphs. The result of some values of the hip sphape morphs are a sharp edge at the side of the glute/thigh/hip area and I use realitvly low values, nothing extreme.
    edited January 2016
    it is quite simple, load a V4 and load a G3F and use wire shaded for view option, you will see the result. YOu can also visit my gallery and have a look at some of my Dixie renders, and if you want to see renders with less clothing visit my gallery at rendo but you just have to look at Dixies faces and you will see the difference between G3F low poly smooth and Dixie (V4)
    The problem with a V4 as SubD Version, smoothing mod and catmull clark legacy - soft corner soft edges is, she is recource eating.
    next thing, hip shape 3 for G3F , since when has a hip shape influence on a ripcage? Hips and Ripcage, two different bodyparts
  • XaatXuunXaatXuun Posts: 874
    if I were to guess, I'd say since G3F.
    I end up using the XYZ parameters scale dials to adjust for that
    I'm still learning the new morph dials I just purchased, so I really didn't want to comment more then just the XYZ scale dials bit
  • Any update on the planned release date?
    edited February 2016
    It's being worked on again now that the Growing Up skin MR sets are complete. As for a release date, I will have to see.
    Post edited by Zev0 on
  • mattew1995mattew1995 Posts: 1
    edited March 2016
    Hi zev0, your products are really awesome! congratulation!  when glute control gf3 will be release?
    Post edited by mattew1995 on
    edited March 2016
    Thanks for the kind words. Working on it.. Just finished the New Bend Control. You can see it here. http://www.daz3d.com/forums/discussion/73277/bend-control-for-genesis-3-females-commercial#latest
    Hope to have both available next month.
    Zev0 said:
    *Snip-
    Hope to have BUY both available next month.
    There, fixed...
  • hi can you make bend control on genesis 2 female?
    I don't think I will be doing that anytime soon. For now, Genesis 3 needs to be brought up to speed. That is where production is focused right now. There are products for Genesis 2 that works similar to Bend Control for Genesis 2 such as http://www.daz3d.com/ideal-beauty-for-genesis-2-and-v6
  • Rod Wise DriggoRod Wise Driggo Posts: 2,333
    Recently noticed that with glute control puppeteer allows to move left and right glutes seperatly whereas with breast control puppeteer only moves both breasts. Would a little update bringing support for single breast movement to breast control puppeteer be possible? Should not mean too much work, does it?
  • Hurdy3DHurdy3D Posts: 1,076
    Arg, postet this one in the worng thread... but now I got the  correct product:
    This product is really great, I use the G3 and G8 version.
    The G8 version has additional some seperate Areola HD morphs. I do a lot of images with G3 characters and miss this this morphs a lot.
    Would it possible to update th G3 version with the seoerate seperate Areola HD morphs? This would be really great!
    Thanks
    edited August 2018
    I will see if it can transfer backwards. I have not done any G8 to G3 morph reverse transfers yet.
    Then I want to say thank you for trying!
    OK I managed to get them across. I'll make an official update when I have time.
    Nice! Thank you so much!
