can someone do Lara Crofts eyes for me?
Toobis
in The Commons
The rest of her face I am making slow progress on but I am finding her eyes impossible to do. Anyone want to have a go at doing them for me? I can't do it for love nor money. Here is what I am doing on the left and on the right is the face I am trying to construct. The file is attached if anyone wants to try or unless you want to do it from the beginning its fine.
anyone want to try? I am persistant on this.
Can't at the moment but here are some things I have noticed which might help you getting a better look:
- upper lip needs to be thinner and have more of that "heart" shape, also adjust it's angle a bit
- lower lip needs a bit more of the, I don't know how I'd call it, "square" shape I guess, yours is way too round
- eyes are way too high, pull them down a bit
- the angle of the tip of the nose is a bit off
- chin needs to be smaller
Those are the adjustments I would make : )
As for the eyes, the major thing to adjust here would be the shape of the upper eyelid. If you can pull it down somehow and adjust it's shape so the eyes appear wider as they do in Lara's model, you are almost there : )
K I will work on that. Thanks.
Which Lara Croft version is your pic from? I have an old version of FaceShop that I use to create "character" morphs for myself...I can try to your version of Lara if I can find a stright on image and a side view image. Or, you can look into "Headshop" and give it a try.....
Can you use a bit better reference?
Yeh right there what SixDs put is accurate. I would appreciate it if you could do that for me please Salem2007.
Ok--it's not great, but maybe it'll work for you. I saved it to your duf so I wouldn't undo any of your changes. I didn't have the textures or boots you used so you'll have to re-apply those. If you select the head and eyes (left or right), you'll see an LCa slider in the "General" parameters. I set it at 50%....any higher gets a little extreme. I might be able to improve it some...I'll try again later. I know I've seen some really goods ones on ShareCG and over at Rendo, if you want something "professional". Hope if works for you!
Thanks Salem its good :D
