Z Poses only providing bottom pose - Mystery solved
omvendtomvendt Posts: 102
edited February 6 in The Commons
Hi, I purchased some pose-packags from Zeddicus. They have poses and then bottom, and top parts of same poses. Or so they say. When I installed using the DIM, I only go the bottom poses and the eye poses. This happended for several pose-packages.
Any idea what to do about this?
Thanks
Post edited by omvendt on
  • TaozTaoz Posts: 10,285
    Which packages?
  • jmucchiellojmucchiello Posts: 830
    Never seen this with Zeddicus and I own a lot of his pose packs. Which packs?
  • omvendtomvendt Posts: 102
    "Jumping Pose Mega Set", for example. I have 26 bottom poses for each of G8 and G9. 34 eye poses but only for G9. No head and neck poses. 17 foot poses, but only for G9. 14 jumping poses for each of G8 and G9. That is it.
    That should have been a lot more
    https://www.daz3d.com/z-active-series-jumping-pose-mega-set-for-genesis-9-and-8-female
  • Richard HaseltineRichard Haseltine Posts: 108,998
    The file list shows full body and top poses http://docs.daz3d.com/doku.php/public/read_me/index/110884/file_list .Where are you looking? If it's in Smart Content try the Content Library pane, it may be a categorisation issue - you can jump to the right folders by right-click on one of the files you do see>View Asset>Vier Asset in Mapped/Virtual Folder (Mapped or Virtual depending on installation method).
    It seems to be fine for me. Have you tried uninstalling and reinstalling?
    1718 x 717 - 428K
    I am embarassed to say that, the reason I couldn't see all the poses was because I had not realized that not all options are shown at the same time in a Content Library folder, if there is a lot of choice. To see all, you select the folder you want, then look at the top where there is a numeral one with an arrow on both sides. Click that right arrow and you are taken to the next page.
