DIM Installed Products Don't Show Up in Smart Content
UthgardUthgard Posts: 883
edited June 2025 in The Commons
I recently ran out of space on my hard drive and made a second DAZ library on another drive. Had a couple of issues, but DIM is now correctly installing the products to the new library, and they show up in the registered folders on the Content Library tab. The only remaining problem is that the newly added products don't show up in Smart Content. I have tried to re-import metadata, and that worked in adding the products I installed beforehand as a test (two products in the new library on the new drive that now show up in smart content) but everything I install afterward does not show, and I'm loathe to re-import metadata every single time I install something. Is there anything I'm missing or that I can do to fix this? I'll really appreciate any help you can provide.
Post edited by Uthgard on
  • Richard HaseltineRichard Haseltine Posts: 109,577
    Check that there are instances of postgresql running as background processes when you are installing - closing DS and immediately starting DIM, for example, can lead to do postgresql running to get the files added.
  • UthgardUthgard Posts: 883
    Hey, thank you very much! Restarting both DIM and DAZ finally did the trick.
