Premium Render Queue issues?
TomhipTomhip Posts: 599
I loved Render Queue 3. It did what I wanted and how I wanted but now that I migrated to a new PC I can no longer find it. I tried using the Premium one but I am not verry happy with it so far.
1. Whenever I add a new render it auto checks boxes for rendering icon and tip. Is there some setting file i can edit to uncheck these by default same way it was in RQ3 ? I cannot find it anywhere and now have to waste 2 clicks for each render.
2. I was able to have RQ3 as a dedicated Pane, I can add something called "Render Settings :: Queue" now, but it is completely blank, with no buttons or any text inside. The one in Render Settings seems to still work fine.
3. Is there a way to bring back RQ3 if I dont want to use Premium one?
  • LeanaLeana Posts: 13,004
    You should still have the original version in your account, you can reinstall it.
  • TomhipTomhip Posts: 599
    edited June 2025
    When I install it via DIM it shows "bytes -1" in it and does not show up in Studio anywhere.
    *Edit* I can see Render Queue 3.0 in my loaded plugins lists but cannot find it in Pane list
    Post edited by Tomhip on
  • Richard HaseltineRichard Haseltine Posts: 109,577
    edited June 2025
    That sounds like a bad installation - go to the Manifests folder, the location is set in DIM's Advanced Settings, and delete the .dsx file there that matches the product (the number at the beginmning is the SKU from the product page), then restart DIM and try installing again.
    Edited to correct file extension.
    I tried to do this today but to my surpraise RQ3 was not installed anymore. After reinstalling it is now working as intended.
    Guess Ill enjoy for the time being as when DAZ5 becomes mandatory it will no longer give option of using RQ3....
