I Really Need a File Folder that will Open and Close
FauvistFauvist Posts: 2,290
edited June 2025 in The Commons
[I Really Need a File Folder that will Open and Close] Just a plain office file folder, the type you keep in a filing cabinet.  I need to be able to open and close it.  I have a lot of file folders that you can't open or close.
Thanks!
  • SilverGirlSilverGirl Posts: 3,412
    If you can't fine an articulated one, I think you could use geometry editor to delete the back and save the front as a scene subset. Then do the same with the other half. Merge them both into a scene and parent one to the other... not elegant, but in theory ought to work so now you can rotate one and it will open?
  • TaozTaoz Posts: 10,302
    This set has one, but I'm not sure if it's the type you're looking for:
    https://www.daz3d.com/interiors-the-classroom
  • LorraineLorraine Posts: 958
    I knew I had one...it's rigged and in this set along with a bunch of other rigged and morphing props. https://www.daz3d.com/professors-office
