Horse armor melting when simulated
SnowSultanSnowSultan Posts: 3,805
https://www.daz3d.com/dforce-royal-armor-outfit-for-daz-horse-3
Could someone explain why this horse armor melts right through the horse when simulating with dForce? There are no custom simulation settings mentioned or included, but when I simulate dForce on a scene with the horse and the armor attached, the horse's hair simulates fine but every part of the armor that uses dforce melts right through the horse and a ground plane. Obviously some settings need to be changed, but I'm not sure which ones at the moment. Thanks in advance for any advice.
  • I haven't tested this lately, but this is what I ran into:
    dForce Royal Armor Outfit issues? - Daz 3D Forums
  • SnowSultanSnowSultan Posts: 3,805
    Thank you very much, that did explain the problem (basically horse armor melts when the horse's hair is loaded first). I did test it without hair and it worked. Would have thanked you sooner but this is the first time I've been able to get through to these forums since this morning. Melting armor, bad gateways all day...fun.   ;)
