Fixing mislabeled UV Set
I made a Daz prop several years ago. When I recently inspected the “Data” directory associated with it, I found a folder within the “UV Sets” that had my vendor name misspelled. There was also a folder with my vendor name spelled correctly. Unfortunately, the prop references the misspelled one.
I guess this happened because I misspelled my own vendor name once during my many iterations of saving the prop when I was making it.
Can I just manually edit the .dsf file and make it reference the correctly spelled vendor name folder, and then delete the misspelled folder?
  • felisfelis Posts: 6,166
    If the file is in the correctly spelled folder, then yes.
