LimbStick and errors
Hi All,
I installed the limbstick product (https://www.daz3d.com/limbstick-for-genesis-3-+-8) from 3D Universe and I keep getting told errors when I try to run the script. There doesnt appears to be a plugin license to enter or anything.
Here is the error I keep getting in the log:
2025-04-30 00:04:01.381 [INFO] :: Loading script: D:/Daz 3D/Applications/Data/DAZ 3D/My DAZ 3D Library/data/cloud/1_83712/scripts/3d universe/limb stick/3du limbstick g3+8.dse
2025-04-30 00:04:01.392 [WARNING] :: \src\pluginsource\DzCustomizeDlg\dsaddonwidgets.cpp(1024): File: data/3D Universe/LimbStick/3duLSError.ui does not exist
2025-04-30 00:04:01.393 [WARNING] :: Script Error: Line 592
2025-04-30 00:04:01.393 [WARNING] :: TypeError: Result of expression 'wLogoWidget' [null] is not an object.
2025-04-30 00:04:01.393 [WARNING] :: Stack Trace:
<anonymous>()@D:/Daz 3D/Applications/Data/DAZ 3D/My DAZ 3D Library/data/cloud/1_83712/scripts/3d universe/limb stick/3du limbstick g3+8.dse:592
2025-04-30 00:04:01.394 [INFO] :: Error in script execution: D:/Daz 3D/Applications/Data/DAZ 3D/My DAZ 3D Library/data/cloud/1_83712/scripts/3d universe/limb stick/3du limbstick g3+8.dse
Any help would be appreciated.
  • LeanaLeana Posts: 13,001
    Judging by the path in the error message, you installed it with Connect. That's often not a good idea for scripts.
  • I used DIM. I can try to reinstall it.
  • Richard HaseltineRichard Haseltine Posts: 109,577
    Make sure your paths are correct - if DS doesn't find the files that DIM installed, and if it is online, it will download and isntall the product when you double-click it. Given the  relative paths in the errors, find the product in Smart Content or Content Library>Products, right-click on the container, and select Uninstal to get rid fo the Connect version.
    Thank you so much! I uninstalled and then went to my account, did a manual download, extracted to Daz, and that seemed to do it. Thanks! Talk about annoying...
