Fill by Bone 4.23
am i missing something or 4.23 doesn't have "fill by bone selection" in weight mapping? did i miss something?
  • SquishySquishy Posts: 719
    edited April 2025
    If you have polygon groups set up to match bones (whether by hand if it's a standalone figure or automatically created during the transfer utility's run, for conformers) you can select geometry by those face groups and then Weight Editing-> assign weight to selected, with the relevant bone/weight map selected, if that helps.
    Post edited by Squishy on
  • Richard HaseltineRichard Haseltine Posts: 109,577
    The command is still in Wiondow>Workspace>Customise under Weight Map Brush - you could add it to a menu or toolbar there if you want (I haven't checked to see that it works, but I would expect so and that it is missing from the UI in error).
  • alexeydualexeydu Posts: 15
    i found that option in that menu but didn't find any way to add it to weight map brush menu
    edited May 2025
    a) Check the new vesiopn, it seems to be in right-click>Weight Editing for me now
    b) if it hadn't reappeared, it works to drag it into Node Weight Map tool Brush Context (or, ideally, right-clcik to create the needed sub-menus
    660 x 681 - 105K
    thanks, i'll try that. what about "convert triax to general"? i didn't find it on the actions on the left
    Is it not in Edit>Figure>Rigging for you? it is for me, in 4.24.0.3. If it is missing or not where you want it the command should be under CCT Weight Mapping on the left of the Customise dialogue.
    i'm trying to transition from 4.16 to 4.23, so i don't know what's where for me. that's the reason why i ask
