Boho Cottage Set Material Issue
I've been working with the Boho Cottage set and am noticing material issues, especially with plants. When rendered, certain materials in the scene are transparent. It's always like this with plants so I thought it was a polygon issue, but even removing the plants, it shows up in other parts of the set. Has anyone else experienced this issue, or know of what I can do to fix it?
I'll be honest, I'm more of a novice Daz user. I primarily render images for use in interactive stories.
2M
  • felisfelis Posts: 6,166
    I don't have it.
    And I can't see others have made comments about it.
    This is a promo image
    The objects in question doesn't look like having CutOut Oppacity.
    What does the inside of the box look like in Surface Settings?
  • siskmilsiskmil Posts: 13
    Cutout Opacity is fine (1)
    I don't see anything out of the ordinary in the surfaces, but I could be missing something.
    356 x 493 - 32K
    357 x 542 - 35K
    349 x 538 - 28K
    Nothing unusual in the surface settings.
    How is the scene lightened? Dome and Scene or Scene only? If Dome and Scene try to set it to Scene only, and see how that works.
    If that doesn't work, try to create a cube, scale it to 50% and copy the surface to the cube and see how it behaves.
  • crosswindcrosswind Posts: 9,750
    I didn't see such issue on my side... but this scene is a bit heavy in terms of geometry. The screenshot  came from the a preview or a render ? It looks a bit weird to me ~~
    What is your Nividia card and spec ?
    2560 x 1392 - 3M
    I found the problem. It's not with the set itself (or even the driver). It's when I use RiverSoft Art Camera Scene Cutaway. If I do not use this tool, it's fine, but as soon as the scene cutaway is used - objects become transparent.
    It was just a test render - I have two devices that I've tried to render it on. both have GeForce RTX 2060 (about time for an upgrade on desktop).
