How to use Yellow?
James
How to use Yellow?
I only get to redeem token, but there's no direction on how to test the character ai generation.
Since this is an orphaned hread anyway I am going to point you to https://www.daz3d.com/forums/discussion/722906/can-anyone-get-yellow-to-work
a) You open the Window Pane for Yellow in DAZ Studio after installing Yellow Plugin & resstarting DAZ Studio the same way as for other DAZ Studio plugins.
b) You log into the Yellow server with the login button on that Yellow Window Pane. The credentials are your DAZ 3D credentials.
c) You write your target morph prompt in the big top text box dialogue in the Yellow Window Pane and click the "Generate" button directly under that text box dialogue.
d) About 30 seconds later your job will finish and show up in the list box below the "Generate" button. Make just the job you want to apply and the Genesis 9 character you want it applied to is selected and click the "Apply and Save" button to the right half below the job list box. If yoou have the Shaping or Parameter tab selected you will see them refresh when you click "Apply and Save"
However, for me at least, no Yellow morph job is being applied to my Genesis 9 character. I don't know why.
