Genesis 9 touch interaction
GolfcheGolfche Posts: 4
edited March 2025 in Daz Studio Discussion
Hey! Sorry, I am very new to actually dive in to daz, and not just make renders. I want to add collusion to Daz figures. Example is a male and female model, he is touching her face or any part of the body, and the skin interacts with the touch. This is not for animation, just for images. Sadly G9 has no smoothing modifier or I can't add one, or I am doing something wrong, and nothing seems to work. I am sorry if I am not using the correct words, or if this has been discussed. I use only G9 figures, and I am absolutely lost. Mathew Morph master doesn't work, as well as Kindredarts Ghost Dynamics. At this point I have no idea what to do, and I cannot use another program, because I suck at 3D. I also turned upside down YouTube for tutorials for skin collusion, and there was nothing for G9....
Post edited by Golfche on
  • Richard HaseltineRichard Haseltine Posts: 109,577
    Addinbg a Smmothing Modifier should just be the same as usual - however, the gensis figures do not, in most areas, have enough mesh resolution to show small effects like finger dents - certainly not on the body. That is why things like compression from clothes have to be handled with HD morphs, which use extra levels of resolution but which we do not have the means to create. You could use a displacement map, which will work on the same additional mesh resolution, but it doesn't show until rendering - and of course you need to create it (in the simplest case using an image editing application).
